Home » Car Questions » Hard to shift gear Nissan Micra 2005
2005 Nissan Micra
I have just bought a Nissan Micra 2005 and have noticed that it’s really hard to shift gear and the engine makes a struggling noise when I press the clutch down while in neutral or gear. Luckily, I have 3 months warranty and will be taking it back to be fixed. I’d like to know what’s most likely to be the cause of this problem please, and if the fix job could easily be masked to make the car run longer?
Hard to shift gear
  • Hard to shift gears – Most likely failing clutch master cylinder and clutch slave cylinder
  • Noise when clutch pedal is pressed – Clutch release bearing failing
The most common fix would be to replace the clutch master and slave cylinders. Also replacing the clutch, clutch pressure plate and release bearing.
