Home » Car Questions » Replace headlight bulb 2011 Buick Enclave
Buick Enclave
I need a bulb put in the right front head light I was told. Will replacing this bulb, also work low and high beam? I was also told it is a little difficult to replace this bulb. Can you tell me how much the bulb should be and how much should the total cost to replace this bulb?
High beam and low beam headlight bulbs are separate. Labor time is 0.8 – 1 hour to replace headlight bulb. So you are looking at around $200 for parts, labor and tax.
OEM Factory Replacement HID Bulb – $69.00 $31.99 (02/2024) w/free shipping
headlight bulb 2011 buick enclave
Shop Automotive
Technical Info
The headlamp relay receives battery positive voltage directly from the battery. The BCM supplies a ground signal to the headlamp relay for normal headlight operation. The BCM also supplies voltage to the beam select relay coil for high beam headlight operation. When the driver places the headlamp switch in the ON position and the dimmer switch is in the low beam position, the headlamp relay supplies current flow through the left and right low beam headlamp fuses to both low and high beam headlamps. Both low beam headlights are grounded through the beam select relay. When activated, the dimmer switch sends a ground signal to the BCM in the high beam position and a momentary ground signal in the flash-to-pass (FTP) position. The BCM then energizes the beam select relay which switches the headlamp grounds from the low beam headlight bulbs to the high beam headlight bulbs illuminating the high beam headlights. With the headlights in the low beam position, the high beams may be momentarily turned ON or flashed by activating the FTP portion of the switch.
When To Change The HID Bulb
Bulb failure, end of life occurs when the bulb gets old and becomes unstable. The bulb may begin shutting itself off sporadically and unpredictably at first, perhaps only once during a 24-hour period. When the bulb begins shutting itself off occasionally, the ballast will automatically turn the bulb back on again within 0.5 seconds. The ballast will re-strike the bulb so quickly that the bulb may not appear to have shut off. As the bulb ages, the bulb may begin to shut off more frequently, eventually over 30 times per minute. When the bulb begins to shut off more frequently, the ballast receives excessive, repetitive current input . Repetitive and excessive restarts or re-strikes, without time for the ballast to cool down, will permanently damage the ballast. As a safeguard, when repetitive re-strikes are detected, the ballast will not attempt to re-strike the lamp. The ballast then shuts down and the bulb goes out.
The following symptoms are noticeable signs of bulb failure:
  • Flickering light, caused in the early stages of bulb failure.
  • Lights go out, caused when the ballast detects excessive, repetitive bulb re-strike.
  • Color change—The lamp may change to a dim pink glow.
Input power to the ballast must be terminated in order to reset the ballast’s fault circuitry. In order to terminate the input power to the ballast, turn the lights off and back on again. Turning the lights off and back on again resets all of the fault circuitry within the ballast until the next occurrence of excessive, repetitive bulb re-strikes. When excessive, repetitive bulb re-strikes occur, replace the starter/arc tube assembly. The ballast will begin the start-up process when the starter/arc tube assembly is replaced. Repeatedly resetting the input power can overheat the internal components and cause permanent damage to the ballast. Allow a few minutes of cool-down time in between reset attempts.
Bulb failures are often sporadic at first, and difficult to repeat. Technicians can identify bulb failure by observing if the problem gets progressively worse over the next 100 hours of operation.
Light Color
White light has a different color rating than regular headlamps. The range of white light that is acceptable is broad when compared to halogens. Therefore, some variation in headlight coloring between the right and left headlamp will be normal. One high intensity discharge (HID) at the end of the normal range may appear considerably different in color from one at the other end of the range. Difference in color is normal. Replace the arc tube only if the arc tube is determined to be at the bulb failure stage.
