Did I not seat the cross piece (Interlock) that goes through the shift tube sideways into the shifting cradle correctly?
It is a 1997 Ford eE50 Econolin Club Wagon. I replaced my auto shift tube that was broke. The shifter is not moving since I put it back together. I believe I did not seat the cross piece (interlock) that is sideways through the new shift tube that seats into the shifting cradle correctly. Currently the shifter does not move.
It never hurts to recheck your work if you think you may have missed a step. However with the Ford Shift Interlock you may want to check for battery voltage at the shift interlock actuator. A weak or dead battery may be at fault. This could be from leaving the door open while working on it for a long period or simply age of the battery. Be sure to check the fuses as well. I have added the wiring diagram below for reference.
Shift Interlock System
The shift interlock system prevents movement of the transmission range selector lever from the PARK position with the ignition switch (11572) placed in the RUN position until the service brake pedal (2455) is actuated or until vehicle power is interrupted. The shift lock actuator is mounted at the base of the steering column and engages the transmission shift selector position insert to lock the transmission column shift selector tube (7212) and transmission range selector lever.
Shift Interlock Wiring Diagram – 1997 Ford E350
(view with Google Chrome or Firefox)
Shift Selector Tube
