Home » Car Questions » Spark plug replacement 1993 Toyota Corolla
1993 Toyota Corolla
Spark Plug Replacement – 1993 Toyota Corolla
1. DISCONNECT Plug wires from spark plugs
Disconnect the plug wires at the rubber boot. DO NOT pull on the wires.
NOTICE: Pulling on or bending the cords may damage the conductor inside.
2. REMOVE SPARK PLUGS Using 16 mm plug wrench, remove the spark plugs.
spark plug replacement
3. CLEAN SPARK PLUGS Using a spark plug cleaner or wire brush, clean the spark plug.
4. VISUALLY INSPECT SPARK PLUGS Check the spark plug for electrode wear, threads damage and insulator damage. If abnormal, replace the plugs. Recommended spark plugs: NDK16R–U or NGK BKR5EYA $9.76 for 4 pack
Shop Automotive
5. ADJUST ELECTRODE GAP Carefully bend the outer electrode to obtain the correct electrode gap. Correct electrode gap: 0.8 mm (0.031 in.)
6. INSTALL SPARK PLUGS Using 16 mm plug wrench, install the spark plug.Torque: 18 N–m (180 kgf–cm, 13 ft–Ibf)
7. RECONNECT Plug wires TO SPARK PLUGS
How to replace spark plugs Video – 1993 Toyota Corolla
How to replace spark plugs Toyota Corolla years 1991 to 2000
