So I just got my first car, a 2008 Honda Accord Ex-l with 55k miles on it from an elderly couple. When I first bought it everything was fine. As I started to drive more and more I started having problems with the transmission.
First off, Its pretty hard to accelerate and when i do i feel the engine working hard to get up to around 2,500/3k rpm, then it gets smoother when it drops down to about 1,500rpm (is this normal?).
Car jerks a little forward
Another thing (my main concern) is that once I’m going anywhere from 30-60 mph and i take my foot off the gas and just let the car glide, as the rpm needle goes down and hits just below the 1k mark the needle jump up to around 1.5k and the car jerks a little forward. (when I’m going around 60-80, it might do this twice). What does this mean? Is that normal?
The last thing might be the same problem but I’m just gonna ask anyways.. Also when I’m breaking from most speeds, once the needle goes below the 1k mark the needle also jumps up (usually between the 500 and the 1k rpm mark).
Whats going on lol?
Ive already changed my break pads and rotors, changed my engine oil (not transmission), and got a fuel injector cleaner. (Not because of this problem, but they needed to be changed anyway.)
Also, whenever i turn my car on I always hear fluid dripping/gurgulling right behind the dashboard. What is causing that?
Thank you very much! Appreciate your service!
VSS? Check engine light?
Car jerking forward? Needle bouncing may all be related to what ever is going on. The needle bouncing isn’t much of a concern as long as the engine isn’t dying. The needle is moving around because the IAC (Idle Air Control) is doing its job.
The first place to start would be to have the check engine light codes scanned. Any present codes will assist in directing us toward the problem. This saves time and money. Also keeps us from trying to guess. Most any local auto parts stores will scan the codes for free. Post the codes below in the comments.
Hello, thanks for your reply. I genuinely appreciate it.
There are no codes showing up.
When I’m driving my car, it’s almost as if its stuck in the wrong gear sometimes. For example, when I’m going down a hill, the car doesn’t glide smoothly (like as if the engine is holding the car back from going with the gravity). Then I’ll feel it jump into the right gear and it’ll just go smoothly down. Also, sometimes when I’m driving (on leveled road) I will press on the gas and the car would barely accelerate. In that case I would have to press down pretty hard on the gas pedal until I feel it move out of that gear and only then will it go back to the “smooth gear” and allow me to accelerate. (If that makes sense.) What is happening?
What I found helps the car from not jumping at the end of a “glide” (from my original question) is to just tap the gas a little before the stop and it will smoothly slow down without jerking forward. Is that normal?
Again, thank you for your help.
With no codes present and so many things going on at the same time, I am going to recommend you have someone drive it from a transmission shop. Allow to drive it while you ride along. This way you can point out exactly whats going on first hand. Anything more and we run the risk of guiding you in the wrong direction.
