Home » Car Questions » How to fix the EPC light on VW Beetle
2003 VW Beetle
I have a 2003 VW beetle with 68k miles on it. Some months ago while driving on a hwy the car felt like it was going to die and a code of EPC came on. I took it to a mechanic and they couldn’t find any issue. Seemed fine but to date several times in the past week, the car feels like it is not getting gas and trying to stall, but no code. What to do?
EPC warning light comes on
Since you did have an EPC code we can look into that issue. Odds are they are related.
Electronic Power Control System (EPC)
EPC diagram for VW Beetle
EPC Light on Volkswagen
The EPC warning light, also known as the Electronic Power Control warning light, is a vehicle warning indicator that indicates a problem with your Volkswagen’s throttle system, such as with the throttle pedal, throttle body, traction control, or cruise control. However, the EPC light can indicate other problems with your Volkswagen, as well. Continue reading for how to fix the EPC light on a Volkswagen.
EPC Car Warning Light
When the EPC light comes on in your Volkswagen, it’s a signal that the vehicle needs to be repaired immediately. Your Volkswagen should have enough power to drive to a car dealership or repair shop, but it should not be driven anywhere else. Your vehicle’s throttle may be limited in power as a built-in mechanism to protect the engine.
How to Fix EPC Light on a VW
The EPC warning light can indicate a variety of problems with your vehicle, some of which can be extremely harmful to your engine. It’s important to get your Volkswagen into a repair shop as soon as possible if it’s displaying the EPC light.
Source: schworervolkswagen.com
