I have the following codes, P-2418 evap emissions open, P-2400 Evap Leak detected, P-2419 Evap emission switch, P-2401 Evap emissions circuit low. I have replaced the gas cap and the fuel leak detection pump already but the check engine light come back on after the a few minutes and not all of the codes clear. Do I have a wiring issue or something else going on? I am at a loss. Thank you Jim
First off it would be great to know which codes are still there. The good news is as long as the check engine light is NOT flashing, it is safe to drive. We can look for the correlation between all the codes and test accordingly.
Mini Code P2148
Description: Evaporative Emission System Switching Valve Control Circuit /Open
Code p2418 Probable Causes
- Sensor or solenoid faulty
- Connector terminal contact is damaged or corroded
- Wire harness – Check harness for correct voltage, open, short to ground or short to voltage
- Update control unit software – Check for the latest control unit update
- Powertrain or Engine Control Module faulty
- EVAP system – Check fuel cap, canister, valves or components
Mini Code P2400
Description: Evaporative Emission System Leak Detection Pump Control Circuit/Open
Code p2400 Probable Causes
- Open fuse
Mini Code P2401
Description: Evaporative Emission System Leak Detection Pump Control Circuit Low
Code p2401 Probable Causes
- Battery voltage low
