How to remove the inner plastic door panel?
Sliding Door Trim Panel
REMOVAL
- Remove sliding door upper frame molding.
- If removing the left sliding door trim panel, remove screw from inside ash receiver bezel.
- Remove screws holding trim panel to inner door panel Sliding Door Trim Panel Screws.
- Disengage push-in fasteners holding trim to door panel around perimeter and upper edge of door Sliding Door Trim Panel.
- Remove sliding door trim panel from vehicle.
