Home » Car Questions » A/C blower motor stopped working Honda Pilot
Honda Pilot
My A/C blower motor stopped working
My A/C blower motor stopped working. I removed it and checked voltage at the plug, 12.4vdc. When I plug it back in, it starts momentarily, but stops. It’s a nonreturnable part based on its electrical nature, so I want to be sure this is the problem.
Use a different source of power when testing the blower motor. I use a Power Probe when doing this in the shop. It allows you to apply power at a push if a button. If you do not have one you can use jumper wires from the battery also. If you find your blower motor is functioning just fine with a separate power source, check your blower motor resistor next.
Power Probe III – Automotive Circuit Tester
power probe lite
Shop Automotive
Blower Motor Replacement
Blower Motor
blower motor diagram 2004 Honda Pilot
ItemPart NumberDescription
1W701696Vacuum reservoir screw
219A566Vacuum reservoir
3Blower motor electrical connector (part of 14401)
4W701696Blower motor screw (3 required)
519805Blower motor
Removal and Installation
  1. Remove the vacuum reservoir screw.
  1. Position the vacuum reservoir aside.
  1. Disconnect the blower motor electrical connector.
  1. Remove the 3 blower motor screws.
  1. Remove the blower motor.
  1. Remove the blower motor wheel from the blower motor.
    1. Remove the push clip.
    1. Remove the blower motor wheel.
blower motor wheel
  1. To install, reverse the removal procedure.
