My driver high beam had short and need to be fixed for inspection.
I wired the head lite up to the right, with all wires and grounds, checked fuse and bulb. But the high beam works on rt but not left only low beam.
Short in High Beam
If the bulb is good then the wiring or connections are the problem. Make sure you have isolated the old wiring from the drivers side head light. This will prevent back feed from the possible short.
