Home » Car Questions » Starter doesn’t operate 1977 F250 4×4: 460 / C6
 Ford F250
I’m trying to start it after it has been sitting for 2 years. I tried to jump-start but starter doesn’t operate. I will check engine crankshaft rotation w/ plugs removed & replace the battery. Is there a way to test the starter without removing it? Where is the neutral cutout switch on this pickup?
Make sure your battery is GOOD and fully charged before testing. The neutral switch is located on the side of the transmission.With the vehicle being so old it may be necessary to check and clean the electrical connections.
Starter wiring diagram 1997 Ford F-250 460 engine
starter wiring diagram
