Home » Car Questions » Wipers stopped working 2002 Dodge Ram 1500 st 4.7l
2002 Dodge Ram 1500
My wipers, turn signal and dash gauges went out. First I checked all fuses which were ok . And then changed the multi-functional switch, still with no results. I also noticed that when I turn the key to auxiliary I do not hear the door chime alarm. The truck still starts up and runs. What can be the problem?
Wipers and turn signals stopped working
Only 2 things I see in common would be the Ground connection at Location G106. Check that first. And the “Front Control Module”.
Wiper Fuses: #8
Wiper Grounds: G106, G103
Turn Signal Fuse: #15, #46, #47, #24, #1, #34, #32, #33
Turn Signal Grounds: G106, G105, G202
2002 Dodge Ram 1500 wiper washer wiring diagram
(best viewed in Google Chrome)
2002-dodge-ram-1500-wiper-washer-1-of-1
2002 Dodge Ram 1500 turn signal wiring diagram
2002-dodge-ram-1500-exterior-lights-exterior-lamps-circuit-1-of-1
