Code P0340 Hyundai 2001 Sonata 2.4
Hyundai Sonata
Code P0340. Looking for diagram for plug. Last mechanic broke connector and spliced wrong connector on and crossed wires. Need to know what wires go where on sensor. Don’t want to short out new sensor. Car starts then dies in 3 seconds. Get 2 diagnostic trouble codes both P0340
Code P0340 Hyundai
Description: Camshaft Position Sensor A Circuit (Bank 1 Or Single Sensor)
Probable Causes:
  1. Sensor or solenoid faulty
  2. Connector terminal contact is damaged or corroded
  3. Wire harness – Check harness for correct voltage, open, short to ground or short to voltage
  4. Update control unit software – Check for the latest control unit update
  5. Powertrain or Engine Control Module faulty
Camshaft Position Sensor Wiring Diagram
