Home » Car Questions » 2006 Toyota Sequoia sr5 would not turn over
2006 Toyota Sequoia
New rack and pinion
Well I put a new rack and pinion in my 2006 Toyota Sequoia but had a issue. I didn’t tighten the drive shaft screw at bottom. But did tighten the two on top I was going to back to tht after I screwed the nozzles in I got the one small looking nozzle but the other would not tighten for nothing it didn’t look stripped it looked fine anyway the sun was going down and I had to get ready for work so I thought to my self I could tighten the one screw on driveshaft and put the nozzle in with my tires on ground anyway.
I put my tires on and took it off the jack and stands and started working on the nozzle which I couldn’t get to tighten but as I’m looking up I see the driveshaft screws are turned the opposite direction, and even tho I didn’t get the nozzle on all the way I just wanted to try to start my truck it would not turn over my truck always turns over all the lights lit the dash and made a weird sound but not even close to starting
You
Do u think there’s a problem tht my screws for my driveshaft are turned the opposite way in which I can’t reach is the reason my truck won’t start or the nozzle not in right or both
Would not turn over
No. I think your battery drained while you were working on it. This is VERY common. Fully charge the battery and the vehicle should start right up as normal.
Your lights and radio will work fine with a weak battery as they require as little as 5 to 15 amps to operate. However a starter requires upwards of 200 amps to operate correctly.
