What is the body code B2340?
Found no listing in the Repair Manuals for code B2340. Searched around and came across the following.
B2340 – Column Reach Motor Stalled
Source: Engine-codes.com, troublecodes.net/bcodes/
B2340 Ford Husky DTC Meaning
B Body Code – Problem is antilock brake system, electronic suspension and steering systems.
2 MFG – Manufacturer Specific
3 IC Module 4X Ref Circuit Intermittent, No Pulses
4 Control Module Throttle Actuator Position Performance
0 Transmission Engaged At High Throttle Angle
Source: http://enginedtc.com/b2340-ford-thunderbird
