Windows, Locks, 1 Mirror problem. Front Driver door controls, lock switch only locks/unlocks front driver’s door. Window switches only open/close driver’s side front & rear windows. Front Passenger door switches do NOT lock/unlock doors or open/close windows. Rear driver’s door window switch works. Rear Passenger door window switch does NOT open/close the window. Keyless entry remotes do NOT work (Batteries are good) Interior lights come on with all door except the front passenger side. Driver’s mirror does adjust, Passenger mirror does NOT adjust. All wires running into the front doors have passed a continuity test. I’m leaning towards the Front Passenger side door module. What do you think?
I have found over the years that the wiring harness in the door jam becomes damaged easily. This is more common than you might think on older vehicles. Not the rule but worth checking. It is quite possible that the door module may be faulty or both.
