I did a scan for codes with an OBDII Scantool for Mercedes only N code came up a10d00 saying power supply too low(stored) N. The next one read 9a4f13 right KEYLESS GO has a malfunction. THERE IS N OPEN CIRCUIT. CURRENT N STORED HOW DO I FIX IT
Did not find any reference to the second code you mentioned. However, there is a Technical Service Bulletin out related to this code A10D00. It refers a wiring harness being damaged in the area of the roof frame. This could affect one or all of the following areas:
- Overhead control panel nonfunctional
- Bluetooth nonfunctional
- Multi-function camera nonfunctional or , malfunctions
TSB Reference Number: LI54.18-P-048131, Date of Issue: November 20, 2009 – The entire TSB along with step by step corrective procedures and pictures are included in each manual. – Purchase Manual
Fault Code A10D00
Mercedes-Benz Code A10D00 Description – The power supply is too low.
Control Unit: MFK – Multi-function camera (A40/11)(MPC212)
I’ve scan my car and it gave me this code ( a10d00, what can I check?
What do I do,i have this fault code a10d00
TSB Reference Number: LI54.18-P-048131, Date of Issue: November 20, 2009 – The entire TSB along with step by step corrective procedures and pictures are included in each auto repair manual. – Purchase Manual –
