Hub bearing replacement 2005 Ford Explorer
The Front Wheel Hub Assembly is going out and I have several Warning Lights showing. ABS, ABTRACK and 4 Wheel High Are all of these associated with the bad Hub?
Yes. The ABS Wheel Speed Sensor is located internally in the Hub Bearing Assembly.
