Home » Car Questions » Replace Drive Belt 1995 Volvo 960 L2.9
Serpentine belt tensioner tool, removal for Volvo 850, S70, V70, 960, V90, S90
Is the replacement of the drive belt idler pulley on 1994 Volvo 960 L2.9 a do-or-yourself job? I have a belt detentioner and basic mechanical skills. The pulley seems accessible on front of block. Single bolt. Any pitfalls?
Serpentine Drive Belt, Replace
1.Rotate or lift the belt tensioner arm, using a suitable tool to relieve tension from drive belt.
2.Remove the drive belt.
3.Clean pulleys and inspect for any bent or damaged pulleys.
4.Reverse procedure to install.
