For my 84 f-150 351cleveland big block with a 4 barrel edlebrock carb with raised edlebrock manifold and heads. can’t find this part anywhere. It is a pigtail that converts a 3 wire distributor to a 4wire electric Ignition module. 3 prong female end to a 4 prong male end on the module. no-one can figure out what I’m talking about or find the part.
Distributor wiring harness pigtail
I get what you are looking for. Here is an example of what I think you want. However, I did not find the part listed at Jegs or Summit Racing. You may just have to make your own wiring harness.
In 1984 Ford used the Duraspark II system. This refers to the Duraspark II control module with a BLUE strain relief bushing, one 4-pin connector, and one 2-pin connector. Another version of the system has an additional 3-pin wiring connector, and two YELLOW strain relief bushing’s. Source: Handyman Dan
