Home » Car Questions » Key Stuck in Ignition 2014 Chevy Cruze
CHEVY CRUZE - KEY STUCK IN IGNITION - HOW TO FIX IT!
key stuck in ignition, gear stick stuck, will not turn on
Key stuck in ignition
Sounds like an issue with the shifter cable.
  • Check proper attachment to shifter
  • verify cable is locked into shifter
  • Check cable is properly attached to transmission
  • verify cable has motion and is not seized
