Home » Car Questions » Rear Bumper Removal 2006 Ford E-150 5.4L Van
2006 Ford E150
Rear bumper. What all is involved in removing the rear bumper??? I have a standard bumper but will be putting a step bumper on it. Is there a different mounting bracket for the Step Bumper or is everything the same???
Everything should be the same. Remove four nuts, install the replacement bumper and tighten the nuts.
Rear Bumper Removal
  1. Remove the 4 retaining nuts from the rear bumper.
  2. Remove the rear bumper.
To install, reverse the removal procedure.
◦To install, tighten to 70 Nm (52 lb-ft).
2006 Ford E150 Rear Bumper Removal Diagram
