Home » Car Questions » 2006 Pontiac G6 remanufactured engine with oil cooler.
looking for reman engine. 1st gen with engine oil cooler.
cannot find one with the cooler.
mechanic says we can use a reman engine without the cooler and just run a bypass around the connections.
Is this advisable?
If a 1st gen Remanufactured Engine is what you want, I would advise continuing to look for it. Have you called Jasper Engines? If they do not have one in stock, they can and will use your engine and  re-manufacture it. They will even warranty the labor if installed by a qualified installer.
