Car shakes and the check engine light flashes 2002 Lincoln ls
When driving the car shakes and the check engine light flashes. What could it be?
Anytime the check engine light flashes the engine should be turned off and repaired before permanent damage is done. The most likely cause for this problem would be an engine misfire. You will want to start by have the engine codes pulled with a scan tool. This process is generally referred to as computer diagnostics.
4 thoughts on “Car shakes and the check engine light flashes 2002 Lincoln ls”
