Where is knock sensor located
The Knock Sensor is located under the intake manifold. There are two of them.
Knock Sensor (KS)
The KS is a tuned accelerometer on the engine which converts engine vibration to an electrical signal. The PCM uses this signal to determine the presence of engine knock and to retard spark timing.
