No fuel at injectors 2004 Ford Explorer Sport Trac
Not getting fuel to the injectors. Fuel pump is working replaced fuel filter also. Any suggestions?
DD: Fuel Rail Pressure (FRP), Fuel Rail Temperature (FRT) and Fuel Rail Pressure Temperature (FRPT) Sensors
2004 PCED On Board Diagnostics
SECTION 5: Pinpoint Tests
Procedure revision date: 03/24/2005
DD: Introduction
DD1 DTC P0192: DETERMINE THE PRESENT FRP V PID VOLTAGE
  • Key ON, engine OFF.
  • Access the PCM and monitor the FRP V PID.
Is the voltage less than 0.25 V?
YesNo
Key in OFF position.
For F-150 Heritage 5.4L Dedicated NGV, and
Crown Victoria Dedicated NGV, GO to DD3.
For E-Series Dedicated NGV, and
F-150 Heritage Bi-Fuel, GO to DD30.
For all others, GO to DD2.
GO to DD28.
DD2 CHECK THE FRP SENSOR FOR LEAKS
  • Key ON, engine running.
  • Idle the engine for 2 minutes.
  • Key in OFF position.
  • REMOVE the FRP Sensor vacuum hose.
  • INSPECT the FRP Sensor and vacuum hose for traces of fuel.
Is fuel present?
YesNo
Key in OFF position. INSTALL a new FRP sensor.
REFER to the fuel system WARNING information.
Clear the PCM DTCs. REPEAT the self-test.
GO to DD3.
DD3 INDUCE THE OPPOSITE FRP SENSOR VOLTAGE
  • FRP Sensor connector disconnected.
Is the voltage greater than 4.5 V?
YesNo
GO to DD4.
DD4 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
  • PCM connector disconnected.
  • Measure the resistance between:
    ( + ) PCM Connector, Harness Side( – ) FRP Sensor Connector, Harness Side
    FRPFRP
Is the resistance less than 5 ohms?
YesNo
GO to DD5.REPAIR the open circuit.
DD5 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
  • PCM connector connected.
  • Measure the voltage between:
    ( + ) FRP Sensor Connector, Harness Side( – ) FRP Sensor Connector, Harness Side
    VREFSIGRTN
Is the voltage between 4 V – 5.5 V?
YesNo
GO to DD6.
GO to C1.
DD6 VERIFY DIAGNOSTIC TOOL COMMUNICATION
  • Connect a 5 amp fused jumper wire between the following:
    Point A FRP Sensor Connector, Harness SidePoint B FRP Sensor Connector, Harness Side
    FRPSIGRTN
  • Access the PCM and monitor the FRP PID.
Does a diagnostic tool communication concern exist?
YesNo
GO to DD7.
GO to DD8.
DD7 CHECK THE FRP V CIRCUIT FOR A SHORT TO VREF
  • Remove the jumper wire(s).
    ( + ) PCM Connector, Harness Side( – ) PCM Connector, Harness Side
    VREFFRP
Is the resistance greater than 10K ohms?
YesNo
INSTALL a new PCM.
(refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)).
REPAIR the short circuit.
DD8 CHECK THE FRP CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
  • Diagnostic tool connector disconnected.
    FRPSIGRTN
    ( + ) PCM Connector, Harness Side( – ) Vehicle Battery
    FRPNegative terminal
YesNo
INSTALL a new PCM.
DD9 DTC P0193: DETERMINE THE PRESENT FRP V PID VOLTAGE
Is the voltage greater than 4 V?
YesNo
GO to DD10.GO to DD28.
DD10 CHECK THE FRP SENSOR FOR LEAKS
Is fuel present?
YesNo
GO to DD11.
DD11 CHECK THE FUEL PRESSURE
Is the pressure greater than 827 kPa (119.9 psi) for Dedicated NGV or greater than 482.6 kPa (70 psi) for all others?
YesNo
For Dedicated NGV
GO to DD23.
For all others:
GO to DD14.
For Dedicated NGV
GO to HB1.
For all others:
GO to Z1.
DD12 DTCS P0190 AND P0191: CHECK FOR FUEL PUMP DTCS
Are DTCs P0230, P0231, P0232, P1233, P1235, or P1237 present?
YesNo
DISREGARD the current diagnostic trouble code (DTC) at this time. DIAGNOSE the next DTC. GO to Section 4, Diagnostic Trouble Code (DTC) Charts.GO to DD13.
DD13 IS DTC P0191 PRESENT IN THE KOEO OR KOER SELF-TEST?
Is DTC P0191 present in the KOEO or KOER self-test?
YesNo
GO to DD19.GO to DD90.
DD14 CHECK THE VREF & SIGRTN CIRCUIT(S)
    VREFSIGRTN
YesNo
GO to DD15.
GO to C1.
DD15 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
    FRPFRP
YesNo
GO to DD16.REPAIR the open circuit.
DD16 VERIFY DIAGNOSTIC TOOL COMMUNICATION
    FRPSIGRTN
YesNo
GO to DD17.
GO to DD18.
DD17 CHECK THE FRP CIRCUIT FOR A SHORT TO VREF
    VREFFRP
YesNo
INSTALL a new PCM.
DD18 CHECK THE FRP CIRCUIT FOR A SHORT TO POWER
    ( + ) FRP Sensor Connector, Harness Side( – ) Vehicle Battery
Is the voltage less than 1 V?
YesNo
GO to DD19.Key in OFF position. REPAIR the short circuit.
DD19 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
  • FRP Sensor connector connected.
  • Allow the engine idle to stabilize.
  • Inspect all the vacuum hoses connected to the intake manifold for leaks.
Are any vacuum hose concerns present?
YesNo
ISOLATE the fault and REPAIR as necessary.GO to DD20.
DD20 CHECK THE FRP CONNECTOR FOR DAMAGE OR CORROSION
  • Inspect the sensor, wiring, and connector for damage, corrosion, or water intrusion.
Is a concern present?
YesNo
REPAIR as necessary.GO to DD21.
DD21 CHECK THE FRP PID
  • Record the FRP PID value within 5 seconds of the key off.
  • Relieve the fuel pressure. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release or Fuel Line Evacuation procedure.
  • Disable the fuel pump.
  • Record the FRP PID value within 5 seconds of completing the fuel system pressure release procedure.
Is the difference between the recorded FRP PID values greater than 34 kPa (5 psi)?
YesNo
For Dedicated NGV and Bi-Fuel vehicles, GO to Pinpoint Test HB.
For all others, GO to Pinpoint Test HC.
GO to DD22.
DD22 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
  • Connect a mechanical fuel pressure gauge.
  • Monitor the mechanical gauge.
  • Compare the FRP PID value to the mechanical gauge.
  • Pressurize the fuel system. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release or Fuel Line Evacuation procedure to restore the fuel system pressure.
  • Allow the fuel pressure to stabilize.
Are the FRP PID values within 34 kPa (5 psi) of the mechanical gauge readings?
YesNo
F-150 Heritage Bi-Fuel, INSTALL a new NG module.
For all others, INSTALL a new PCM.
REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM).
For all others, INSTALL a new FRP sensor.
REFER to the fuel system WARNING information at the beginning of Pinpoint Test HC. GO to Pinpoint Test HC.
DD23 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
  • NG Module connector disconnected.
    ( + ) NG Module Connector, Harness Side( – ) FRP Sensor Connector, Harness Side
    FRPFRP
YesNo
GO to DD24.REPAIR the open circuit.
DD24 VERIFY DIAGNOSTIC TOOL COMMUNICATION
  • NG Module connector connected.
    FRPSRtn
YesNo
GO to DD25.
GO to DD26.
DD25 CHECK THE FRP CIRCUIT FOR A SHORT TO SREF
    FRPSRef
YesNo
INSTALL a new NG module.REPAIR the short circuit.
DD26 CHECK THE FRP CIRCUIT FOR A SHORT TO POWER
YesNo
GO to DD27.
DD27 CHECK THE FRP VOLTAGE PID DURING FUEL RAIL PRESSURE RELIEF
  • Crank the engine.
Is the voltage between 0.4 V – 0.6 V?
YesNo
GO to HB1.
DD28 CHECK THE FRP VOLTAGE PID DURING FUEL RAIL PRESSURE RELIEF
  • Disable the inertia switch.
  • Monitor the FRP voltage while cranking the engine.
  • FRP voltage decreases as the fuel rail pressure drops and stabilizes when the fuel rail pressure reaches atmospheric pressure.
    VehicleLow LimitHigh Limit
    F-1501.0V1.5V
    All others0.2V0.7V
Is the voltage value within specification?
YesNo
GO to DD29.
DD29 PERFORM A THOROUGH WIGGLE TEST ON THE FRP HARNESS
  • Reset the inertia switch.
  • Perform a thorough wiggle test on the FRP Sensor harness.
Is the FRP signal stable?
YesNo
GO to Z1.
Repair as necessary.
DD30 CHECK THE SREF AND SRTN CIRCUITS FOR OPEN IN THE HARNESS
    SRefSRtn
YesNo
GO to DD31.
GO to C25.
DD31 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
    FRPFRP
YesNo
GO to DD32.REPAIR the open circuit.
DD32 CHECK THE FRP CIRCUIT(S) FOR A SHORT TO SRTN OR GND IN THE HARNESS
    FRPSRtn
YesNo
GO to DD33.REPAIR the short circuit.
DD33 INDUCE THE OPPOSITE FRP SENSOR VOLTAGE
  • Diagnostic tool connector connected.
    FRPSRef
  • (If the PID cannot be accessed, follow the NO action to take).
Is the voltage greater than 4.75 V?
YesNo
Key in OFF position. INSTALL a new NG module.
DD34 DTCS P0181, P0182 OR P0183: ARE DTCS P0181, P0182 OR P0183 PRESENT IN THE KOEO OR KOER SELF-TEST?
Are DTCs P0181, P0182 or P0183 present in the KOEO or KOER self-test?
YesNo
F-150 Heritage Bi-Fuel, GO to DD75.
For all others, GO to DD35.
F-150 Heritage Bi-Fuel, GO to DD86.
For all others, GO to DD88.
DD35 DETERMINE THE PRESENT FRT PID VOLTAGE
  • Allow vehicle temperatures to stabilize prior to temperature sensor tests.
  • Normal test range 100 Deg C (212 Deg F) to 0 Deg C (32 Deg F).
  • Access the PCM and monitor the FRT V PID.
Is the voltage greater than 0.4 V?
YesNo
GO to DD36.GO to DD37.
DD36 FRT SENSOR RESISTANCE TEST
  • FRT Sensor connector disconnected.
  • Sensor resistance measurements can be compared to the table above when the sensor temperature is known.
    ( + ) FRT Sensor Connector, Component Side( – ) FRT Sensor Connector, Component Side
    FRTSIGRTN
Is the resistance between 2K ohms – 96K ohms?
YesNo
GO to DD37.
Key in OFF position. INSTALL a new FRT sensor.
DD37 CHECK THE FRT AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
    ( + ) PCM Connector, Harness Side( – ) FRT Sensor Connector, Harness Side
    FRTFRT
    SIGRTNSIGRTN
Are the resistances greater than 5 ohms?
YesNo
REPAIR the open circuit.GO to DD38.
DD38 CHECK THE FRT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
    FRTSIGRTN
    FRTNegative terminal
YesNo
GO to DD39.REPAIR the short circuit.
DD39 VERIFY DIAGNOSTIC TOOL COMMUNICATION
    Point A FRT Sensor Connector, Harness SidePoint B FRT Sensor Connector, Harness Side
    FRTSIGRTN
YesNo
GO to DD41.
REMOVE the jumper(s).
GO to DD40.
DD40 CHECK THE SENSOR SIGNAL CIRCUIT FOR A SHORT TO SIGRTN
    ( + ) FRT Sensor Connector, Harness Side( – ) FRT Sensor Connector, Harness Side
    FRTSIGRTN
YesNo
GO to DD41.
CLEAR the DTCs. REPEAT the self-test.
DD41 CHECK THE SENSOR SIGNAL FOR A SHORT TO VREF
    FRTVREF
YesNo
INSTALL a new PCM.
REPAIR the short circuit to VREF.
DD42 DTC P0180: PERFORM A THOROUGH WIGGLE TEST ON THE FRT SENSOR HARNESS
  • Perform a thorough wiggle test on the FRT Sensor harness.
Is the FRT signal stable?
YesNo
GO to DD44.
DD43 KOEO AND KOER DTC P0181: CHECK THE FRT_V PID
    Vehicles with a 60-pin NG module0.4V5.0V
    All others0.4V4.5V
YesNo
GO to DD34.The concern is elsewhere. RETURN to Symptom Charts, Symptom Charts for further direction.
DD44 COMPARE THE PIDS AFTER STABILIZING THE VEHICLE TEMPERATURE
  • Access the PCM and monitor the FRT_TEMP, CHT and ECT PIDs.
Are the temperature PIDs nearly equal in value?
YesNo
The fault is not present at this time
GO to Z1.
DD45 DTC P0192: DETERMINE THE PRESENT FRP V PID VOLTAGE
YesNo
Crown Victoria Dedicated NGV, GO to DD47.
For all others, GO to DD46.
GO to DD58.
DD46 CHECK THE FRPT SENSOR FOR LEAKS
  • REMOVE the FRPT vacuum hose.
  • INSPECT the FRPT and vacuum hose for traces of fuel.
Is fuel present?
YesNo
Key in OFF position. INSTALL a new FRPT sensor.
GO to DD47.
DD47 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
  • FRPT Sensor connector disconnected.
    ( + ) FRPT Sensor Connector, Harness Side( – ) FRPT Sensor Connector, Harness Side
    VREF – Pin 2SIGRTN – Pin 4
YesNo
GO to DD48.
GO to C1.
DD48 INDUCE THE OPPOSITE FRPT SENSOR VOLTAGE
YesNo
GO to DD49.
DD49 CHECK THE FRPT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
    FRPSIGRTN
YesNo
INSTALL a new PCM.
DD50 DTC P0193: DETERMINE THE PRESENT FRP V PID VOLTAGE
YesNo
Crown Victoria Dedicated NGV, GO to DD52.
For all others, GO to DD51.
GO to DD58.
DD51 CHECK THE FRPT SENSOR FOR LEAKS
  • REMOVE the FRPT Sensor vacuum hose.
  • INSPECT the FRPT Sensor and vacuum hose for traces of fuel.
Is fuel present?
YesNo
GO to DD52.
DD52 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
YesNo
GO to DD53.
GO to C1.
DD53 CHECK THE FRP V CIRCUIT FOR A SHORT TO POWER
    ( + ) FRPT Sensor Connector, Harness Side( – ) Vehicle Battery
    FRP – Pin 1Negative terminal
Is the voltage greater than 10.5 V?
YesNo
Key in OFF position. REPAIR the short circuit.GO to DD54.
DD54 VERIFY DIAGNOSTIC TOOL COMMUNICATION
    Point A FRPT Sensor Connector, Harness SidePoint B FRPT Sensor Connector, Harness Side
    FRP – Pin 1SIGRTN – Pin 4
YesNo
GO to DD55.
GO to DD56.
DD55 CHECK THE FRP V CIRCUIT FOR A SHORT TO VREF
    VREFFRP
YesNo
GO to DD57.REPAIR the short circuit.
DD56 INDUCE THE OPPOSITE FRP V SENSOR VOLTAGE
Is the voltage less than 0.05 V?
YesNo
Key in OFF position. INSTALL a new PCM.
GO to DD57.
DD57 CHECK THE FRP AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
    ( + ) PCM Connector, Harness Side( – ) FRPT Sensor Connector, Harness Side
    FRPFRP – Pin 1
    SIGRTNSIGRTN – Pin 4
YesNo
DD58 PERFORM A THOROUGH WIGGLE TEST ON THE FRPT HARNESS
  • Perform a thorough wiggle test on the FRPT Sensor harness.
YesNo
GO to Z1.
DD59 DTCS P0190 AND P0191: CHECK FOR FUEL PUMP DRIVER MODULE (FPDM) DTCS
  • Check for self-test DTCs.
Are DTCs P1233, P1235 or P1237 present?
YesNo
DISREGARD the current diagnostic trouble code (DTC) at this time. DIAGNOSE the next DTC. GO to Section 4, Diagnostic Trouble Code (DTC) Charts.GO to DD60.
DD60 CHECK THE FRPT CONNECTOR FOR DAMAGE OR CORROSION
YesNo
REPAIR as necessary.GO to DD61.
DD61 CHECK THE VREF AND SIGRTN CIRCUITS FOR AN OPEN IN THE HARNESS
Is the voltage between 4.5 V – 5.5 V?
YesNo
GO to DD62.GO to C1.
DD62 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
  • FRPT Sensor connector connected.
YesNo
ISOLATE the fault and REPAIR as necessary.GO to DD63.
DD63 CHECK THE FRP PID
  • Relieve the fuel pressure. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release procedure.
YesNo
GO to Pinpoint Test HC.GO to DD64.
DD64 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
  • Pressurize the fuel system. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release procedure to restore the fuel system pressure.
YesNo
INSTALL a new PCM. REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM).
DD65 DTCS P0182 OR P0183: DETERMINE THE PRESENT FRT PID VOLTAGE
Is the voltage less than 0.4 V?
YesNo
GO to DD66.GO to DD69.
DD66 FRT SENSOR RESISTANCE TEST
    ( + ) FRPT Sensor Connector, Component Side( – ) FRPT Sensor Connector, Component Side
    FRT – Pin 3SIGRTN – Pin 4
YesNo
GO to DD67.
DD67 CHECK THE FRT AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
    FRTFRT – Pin 3
YesNo
REPAIR the open circuit.GO to DD68.
DD68 CHECK THE FRT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
    FRTSIGRTN
YesNo
GO to DD69.REPAIR the short circuit.
DD69 CHECK FOR OPEN IN THE HARNESS
Is the voltage less than 0.2 V?
YesNo
GO to DD70.
DD70 CHECK THE SIGNAL AND SIGRTN CIRCUITS FOR AN OPEN IN THE HARNESS
    ( + ) FRPT Sensor Connector, Harness Side( – ) PCM Connector, Harness Side
    FRT – Pin 3FRT
    SIGRTN – Pin 4SIGRTN
Are the resistances less than 5 ohms?
YesNo
GO to DD71.REPAIR the open circuit.
DD71 CHECK THE SENSOR SIGNAL FOR A SHORT TO VREF
    FRTVREF
YesNo
INSTALL a new PCM.
DD72 DTC P0180: PERFORM A THOROUGH WIGGLE TEST ON THE FRPT SENSOR HARNESS
YesNo
GO to Z1.
DD73 KOEO AND KOER DTC P0181: CHECK THE FRT_V PID
Is the voltage between 0.4 V – 4.5 V?
YesNo
GO to DD74.The concern is elsewhere. RETURN to Symptom Charts, Symptom Charts for further direction.
DD74 COMPARE THE PIDS AFTER STABILIZING THE VEHICLE TEMPERATURE
YesNo
GO to Z1.
DD75 ARE DTCS P0182 OR P0183 PRESENT IN THE KOEO OR KOER SELF-TEST?
Are DTCs P0182 or P0183 present in the KOEO or KOER self-test?
YesNo
GO to DD79.GO to DD76.
DD76 KOEO AND KOER DTC P0181: CHECK THE COOLING SYSTEM
  • Verify the cooling system is operating normally.
  • WARNING: TO AVOID PERSONAL INJURY DO NOT UNSCREW THE COOLANT PRESSURE RELIEF CAP WHILE THE ENGINE IS OPERATING OR HOT. THE COOLING SYSTEM IS UNDER PRESSURE. STEAM AND HOT LIQUID CAN COME OUT FORCEFULLY WHEN THE CAP IS LOOSENED SLIGHTLY.
  • Check the vehicle coolant level.
Is the cooling system OK?
YesNo
GO to DD77.
REFER to Workshop Manual, Section 303, Engine Cooling for cooling system diagnostics.
DD77 CHECK THE RESISTANCE OF THE FRP SENSOR WITH THE ENGINE OFF
    FRTSRtn
Is the resistance within specification?
YesNo
GO to DD78.INSTALL a new FRT sensor.
DD78 CHECK THE RESISTANCE OF THE CHT SENSOR WITH THE ENGINE RUNNING
    CAUTION: While conducting checks with a running engine ensure adequate safety precautions are observed to prevent contact with moving engine parts. For example; ensure ties or loose clothing do not come into contact with the cooling fan or drive belts.
  • Vehicle must be at normal operating temperature.
    FRTSRtn
YesNo
Check the FRT & NG connector for damage or corrosion.
Check the FRT % SRtn circuit(s) between the sensor and the NG module.
Service as necessary
DD79 KOEO AND KOER DTCS P0182 OR P0183: CHECK THE TEMPERATURE SENSOR SIGNAL
  • Access the NG and monitor the FRTMPAB PID.
Is the temperature greater than 125°C (257°F)?
YesNo
GO to DD80.
GO to DD82.
DD80 CHECK FOR A GROUNDED CIRCUIT
Is the temperature less than -20°C (-4°F)?
YesNo
GO to DD81.
DD81 CHECK THE SENSOR SIGNAL FOR A SHORT TO GROUND
    FRTSRtn
    FRTGround
YesNo
DD82 CHECK THE RESISTANCE OF THE FRT SENSOR WITH THE ENGINE OFF
    FRTSRtn
YesNo
GO to DD83.INSTALL a new FRT sensor.
DD83 CHECK THE FRT CIRCUIT FOR A SHORT TO POWER
    FRTGround
YesNo
GO to DD84.
Key in OFF position. REPAIR the short circuit to PWR.
DD84 CHECK THE FRT & SRTN CIRCUIT(S) FOR AN OPEN
    ( + ) FRT Sensor Connector, Harness Side( – ) NG Module Connector, Harness Side
    FRTFRT
    SRtnSRtn
YesNo
GO to DD85.REPAIR the open circuit.
DD85 CHECK THE SENSOR SIGNAL FOR A SHORT TO SREF
    ( + ) NG Module Connector, Harness Side( – ) NG Module Connector, Harness Side
    FRTSRef
YesNo
DD86 CONTINUOUS MEMORY DTCS P0182 OR P0183: INTERMITTENT CHECK
  • While observing the PID, carry out the following:
  • Tap on the sensor to simulate road shock.
  • Wiggle the sensor connector.
  • Shake, wiggle, and bend the FRT & SRtn circuit(s). Check the FRT & SRtn circuit(s) between the sensor and the NG module.
Is there a large change in the temperature reading?
YesNo
ISOLATE the fault and REPAIR as necessary.GO to DD87.
DD87 CHECK THE FRT & NG CONNECTOR FOR DAMAGE OR CORROSION
Are the connectors and terminals OK?
YesNo
DD88 CONTINUOUS MEMORY DTCS P0182 OR P0183: INTERMITTENT CHECK
  • Wiggle, shake, and bend small sections of the wiring harness while working from the FRT Sensor to the PCM.
Is there a large change in the voltage reading?
YesNo
ISOLATE the fault and REPAIR as necessary.GO to DD89.
DD89 CHECK THE FRT & PCM CONNECTOR FOR DAMAGE OR CORROSION
YesNo
DD90 CONTINUOUS MEMORY DTCS P0190 AND P0191: CHECK THE FRP CONNECTOR FOR DAMAGE OR CORROSION
YesNo
REPAIR as necessary.GO to DD91.
DD91 CHECK THE SIGRTN, SREF, SRTN, AND VREF CIRCUITS FOR AN OPEN IN THE HARNESS
  • For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel.
    SRefSRtn
  • For all others.
    VREFSIGRTN
YesNo
GO to DD92.
F-150 Heritage Bi-Fuel, GO to C25.
For all others, GO to C1.
DD92 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
YesNo
ISOLATE the fault and REPAIR as necessary.GO to DD93.
DD93 CHECK THE FRP PID
YesNo
GO to DD94.
DD94 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
YesNo
GO to DD95.
DD95 CHECK THE FUEL SYSTEM AND FRP SENSOR CIRCUITS
  • Check the fuel delivery system for concerns.
  • Wiggle, shake, and bend small sections of the wiring harness while working from the FRP Sensor to the PCM.
  • Check the FRP connector for damage or corrosion.
YesNo
ISOLATE the fault and REPAIR as necessary.GO to Z1.
