I have a 2006 Hyundai Santa Fe V6 recently bought. I was told the driver side window master switch needed to be replaced. So I bought a certified used one. Put it in and the windows are still not working. None of the windows will work in fact please help????
Power Window Won’t Work
First thing to do would be to confirm power is getting to the master switch you just installed. The old one may not have been bad either. Battery positive gets tot he power window master switch through a fuseible link and a power window relay. Use the provided power window wiring diagram below for reference.
