About 3 months ago started acting like no power for about one second then would kick back in. About two weeks ago it started not wanting to shift into 4th gear and after two less than a mile drives since it jerks like a manual first time learning driver shifting into 4th gear (mostly in auto not so much when in manual mode). Once into 5th gear it’s fine as like 1-3rd gears. Just going into 4th. I’m disabled and need to get this fixed doe my weekly doctor’s visits. One mechanic said need new transmission, another said “it’s normal and gas saver lol” which we know that’s not the case if it’s never done it before. Ive read a wave plate or solenoid. Did find one very very very small hose leaked front drivers side lower hose by front quarter panel / bumper area but it’s so minute it’s not low. Don’t want to buy new transmission if not necessary. Thank you for your time. Exhausted Grammy.
The best first course action would be to have the transmission codes read at a Transmission specialty shop. This should tell you the exact problem area. If the transmission fluid color looks good, my guess would be a faulty/sticking solenoid. This is a common failure part that exhibits the symptoms you are describing.
