Home » Car Questions » Air Bag replacement 2005 Chevrolet Classic
Chevy Classic
I’m wanting to replace the drivers and passengers airbags on my own. I have took the drivers and passengers airbag out allready. I’m thinking just take the battery out of the car and pulling the fuses that have to do with the airbag. Then reinstall !!! But I want the Airbags to Reset the way they’re suppose to. Could you help me out, it would be greatly appreciated. Michael
Here is what I found in one of the manuals:
Air Bag System Disarming & Arming
Disarming
Zone 3
1.Ensure front wheels are pointed straight-ahead.
2.Turn ignition key off and remove ignition key from switch.
3.Remove access panel from lefthand instrument panel wiring harness junction block.
4.Remove AIR BAG fuse from junction block.
5.Remove CPA cover from steering wheel module coil connector. Connector is located above lefthand instrument panel wiring harness junction block.
6.Disconnect steering wheel module coil connector.
Zone 5
5.Remove access panel from righthand instrument panel wiring harness junction block.
6.Remove CPA (CPA) cover from instrument panel module connector. Connector is located above righthand instrument panel wiring harness junction block.
7.Disconnect instrument panel module electrical connector.
Arming
Zone 3
1.Connect steering wheel module coil connector.
2.Install CPA cover onto steering wheel module coil connector. Connector is located under lefthand side of instrument panel.
3.Install AIR BAG fuse into junction block.
4.Install junction block access panel onto lefthand side of instrument panel.
5.From a safe position at sides of or below air bag modules, turn ignition On.
6.Ensure SIR lamp flashes seven times and turns off.
Zone 5
1.Connect instrument panel module electrical connector.
2.Install CPA cover onto instrument panel module connector. Connector is located above righthand instrument panel wiring harness junction block.
3.Install junction block access panel onto righthand side of instrument panel.
4.Install AIR BAG fuse into lefthand junction block.
5.Install junction block access panel onto lefthand side of instrument panel.
6.From a safe position at sides of or below air bag modules, turn ignition On.
7.Ensure SIR lamp flashes seven times and turns off.
