Auto Repair Questions
Air conditioning compressor won’t come on – SOLVED
1998 Chrysler Sebring
I have a 1999 Chrysler Town and Country. The air compressor for the ac won’t come on.
The happens when the low pressure switch indicates low pressure. This usually means the Freon level is too low. Adding more Freon will generally cause the compressor to turn on. This video will show you how easy it is to add Freon yourself.
Mary Childress
Recent My Questions
2000 Honda Civic engine shutters and electrical accessories will stop working
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
1 week ago
LED Fog Light Upgrade Jeep Wrangler Video
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
2 weeks ago
GM Low brake fluid warning light RECALL – How soon should I get it fixed?
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
2 months ago
Jeep Wrangler Frame Repair Kit Installation Video
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
2 months ago
02 Grand Caravan Sport
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
2 months ago
