I’m hearing a clicking noise in my transmission. Is it supposed to be there because the bottom of the trans is open I can see the flywheel spinning?
No it is not supposed to. This noise can be common to several things.
- A rock or piece of debris is lodged near the flywheel/Flex-plate
- One of the torque converter bolts is loose and rubbing against something
- The flywheel/Flex-plate is cracked
