Abs light on dash is on, how do I repair it?
Connect an ABS scan tool or code reader to the data link connector under the dash and read the ABS Codes. Once you have the codes it will guide you to the root of the problem. Could be as simple as a faulty wheel speed sensor or bad ground.
