Home » Car Questions » Engine overheating at idle or setting still.
2004 Volvo xc70
I have a very nice Volvo. I have an overheating issue that I cannot seem to figure out. I’m baffled. I could use someone who knows more than me. I could be way off on my reasoning.
Overheating Issue
1. When in stop-and–go or standstill traffic (or at idle) ONLY, my car is running hot or overheating. It varies on how long it takes. It does NOT happen when the car is steadily moving (even at low speeds).
Overheating Symptoms
1. The indicator will say to reduce the speed as the car is running hot.
2. I am NOT typically losing coolant.
3. When I start to drive, the warning goes away.
4. On a few occasions, it has said that the engine is hot and to stop the engine.
5. When it first started, I could not find a leak and added a bottle of stop leak. Dumb, I know. No lectures. But, it stopped overheating for about a week.
6. When the stop leak did not solve it, I drained but did not flush the system. (The coolant looked new.)
7. With the fresh coolant, I added an additive that also contained stop leak. No lectures. I ran the car at idle with the heat on high for more than two hours while continually gauging the coolant level. No issue with overheating. This too stopped the issue for about a week.
8. Each time I added stop leak, I ran the car very hard and replicated situations where it was overheating for an extended period of time without incident.
Eliminated Issues
1. I tried a new cap. Was not it.
2. The indicator is working. The car is running hot.
3. It’s not a head gasket. Again, I’ve only lost coolant if it was actually running hot and through the cap. I’m NOT losing coolant.
4. Again, it is not a head gasket. There is no oil in the coolant or vice versa.
5. It can’t be the thermostat stuck closed, as it would overheat on the highway.
6. The thermostat can’t be stuck open, as it would run cool.
Possible but Unlikely Items
1. A bad water pump could be the issue. BUT, it makes no sense that stop leak temporarily stopped and slowed the overheating under the same conditions.
2. For the same reason, I don’t see the coolant temperature sensor being the culprit. Stop leak would have done nothing to affect the issue.
3. While I could try a different cap in the assumption I got a defective one, it would not explain the temporary stop leak fix. It’s a closed system with the cap on the reservoir.
4. I don’t think it’s trapped air, as it’s self bleeding and was an issue before I replaced the coolant.
Only Possible Thing I See
1. Could it be a leak in the reservoir tank? It’s a closed system. It has a two-piece plastic reservoir that is factory fitted together. The seam is just above the fill line. There are no visible cracks.
Any thoughts?
Two immediate thoughts. One, you stated “The thermostat can’t be stuck open, as it would run cool”. Actually the engine will overheat in this instance as the coolant will not stay in the radiator long enough to cool it down.
My second thought would be the cooling fan. The engine while moving is not having an issue but it does while setting still. When the vehicle is setting still it is reliant upon the cooling fans to do its job. Check for failing fan motor relays and or fan motors if equipped.
2 thoughts on “Engine overheating at idle or setting still.”
  1. Interesting on the thermostat. I’ll check on that. That’s why I needed someone smarter than me. Thanks so much.
  2. I’m absolutely positive is not the cooling fans. They are kicking on when she is running hot. That’s my first indicator.
