Home » Car Questions » Cadilac SRX wont go into park
2008 Cadfillac SRX
Car wont go completely into park
Shifter assembly. Micro switch inside the shifter isn’t reading park. Requires replacement of the entire assembly unless you’re willing to take it apart and wire the switch closed.
Sounds like you need to adjust the the nut on the shifter linkage to make that last 1/4 of an inch to get it all the way in park. From underneath the car, above the transmission is the slotted shifter linkage attachment for the trans. There is a 10mm nut that you can loosen and then move in that slot and then re-tighten to correct this condition.
Source: suprane1
Cadillac STS SHIFT TO PARK problem
RECALL NOTICE for transmission cable
General Motors LLC (GM) is recalling certain model year 2013-2014 Cadillac ATS vehicles manufactured April 23, 2012, to March 20, 2014, and 2014 Cadillac CTS vehicles manufactured June 10, 2013, to March 20, 2014.
In the affected vehicles, the transmission shift cable may detach from either the bracket on the transmission shifter or the bracket on the transmission.
The recall is expected to begin in early August 2014. Owners may contact Cadillac customer service at 1-800-458-8006. GM’s number for this recall is 14179.
