starter turns motor after about 1 or 2 seconds starter spins do i need new starter
Are you testing with a NEW or fully charged battery?
Make certain your battery connections and battery cable connections are clean. Also check for clean Starter motor connections. Then you could check the clutch pedal switch for acting up or not being depressed fully.
