This is specifically a question about the interior of the vehicle.
My wife’s 2012 GMC Acadia front-wheel drive with a little over 71k miles. The top of the center console where it connects to the dashboard came loose and I pressed it back into place. Except for the right side – it is being stubborn.
1. Is this something my wife should be concerned about?
2. Is it something that I can fix myself?
The instrument panel center accessory trim plate just snaps into place. To remove it calls for use of a suitable flat bladed trim tool. If you or someone has removed it to do a repair or work on a radio or something they may not have installed the internal components correctly causing it to be a bit stubborn.
2012 GMC Arcadia Radio Navigation Removal
