Home » Car Questions » Battery light on 2009 Dodge Journey 2.4L
2009 Dodge Journey
Battery Light stays on. New battery alternator good.
The battery light comes on when the battery is not being charged. Check to make sure the alternator is installed correctly. Meaning look to make certain the electrical connections are all hooked up properly.  Next check the Fusible link to make sure it isn’t blown. Finally check your battery cable connections.
2009 Dodge Journey Charging System Wiring Diagram
2009-dodge-journy-charging-system-wiring-diagram
