Home » Car Questions » Power to dash but no sound 2007 Ford Falcon fa
2007-ford-falcon
I have power to dash but no sound turning key
This would be normal if the vehicle is still in gear or if the battery is weak. The starter requires around 250 amps to turn the engine over where as the dash lights require less than 5 amps. Most likely cause would be a weak/dead battery.
