My vehicle is a Volvo V50 2.4L petrol, 2004-2010 model. I have read the diagnostic and report shows fault:
400A, Canister purge valve, circuit fault, permanent
I am having a hard time locating the canister purge valve in the bonnet/ under the hood. Should I replace with new part or could it be a hose which is bent or damaged. First issue is locating, i have looked online and cant seem to find a video or layout. Thank you for the service, best regards. James
Volvo Code 400A
Canister Purge Valve. Faulty Signal
Code 400A Description
The engine control module(ECM) detects a fault in the function of the EVAP valve by analyzing the signal from the manifold absolute pressure (MAP) sensor.
The diagnostic trouble code 400A is stored if the ECM registers that the EVAP valve is stuck.
Code 400A Possible Causes
- The hose between the intake manifold and evaporative emission system (EVAP) valve is defective, blocked or trapped
- The hose between the evaporative emission system (EVAP) valve and canister is defective, blocked or trapped
- The EVAP valve has stuck in the open position
- The EVAP valve has stuck in the closed position
EVAP Canister Purge Valve Location
Component #6
Thanks for the detailed reply, i found the item and repaired, cheers
