Airmatic relay and fuse do not have power. All other fuses have power. Why would these two things not be supplying power?
Could be a faulty connection or faulty module. Check the wiring for continuity. Use the provided diagram below to help assist in understanding the circuit.
2004-mercedes-benz-s430-airmatic-module-relay-wiring-diagram
Wiring Diagram Legend
- N51 – AIRmatic Control Module
- A9/1 – AIRmatic compressor unit
- A9/1m1 – AIRmatic compressor motor
- A9/1y1 – AIRmatic pressure reduction valve
- K40/7 – Fuse and Relay
- K40/7kO – Air Compressor Relay
- K40/7f32 – Fuse 32
- X4/10 – Terminal block and fuse box (circuit 30 and 61)
- X4/10f3 – Fuse 3
How to Replace the AIR Shocks with conventional shocks
Front Installation: 2000 to 2006 Mercedes S430 Suspension Conversion Kit By Strutmasters
Visit FreeAutoMechanic on YouTube!
