Home » Car Questions » AIRmatic problems Mercedes Benz S430 2004
2000 Mercedes S430
Airmatic relay and fuse do not have power. All other fuses have power. Why would these two things not be supplying power?
Could be a faulty connection or faulty module. Check the wiring for continuity. Use the provided diagram below to help assist in understanding the circuit.
2004-mercedes-benz-s430-airmatic-module-relay-wiring-diagram
Wiring Diagram Legend
  • N51 – AIRmatic Control Module
  • A9/1 – AIRmatic compressor unit
  • A9/1m1 – AIRmatic compressor motor
  • A9/1y1 – AIRmatic pressure reduction valve
  • K40/7 – Fuse and Relay
  • K40/7kO – Air Compressor Relay
  • K40/7f32 – Fuse 32
  • X4/10 – Terminal block and fuse box (circuit 30 and 61)
  • X4/10f3 – Fuse 3
How to Replace the AIR Shocks with conventional shocks
Front Installation: 2000 to 2006 Mercedes S430 Suspension Conversion Kit By Strutmasters
Visit FreeAutoMechanic on YouTube!
