Auto Repair Questions
Chevy Code P1635 Chevy Lumina 2001
2001-chevy-lumina
When I try to drive my 2001 Chevy Lumina I can floor it and it hardly goes. Then kicks in and does this back and to. I got error code p1635 . Also have replaced the fuel filter, fuel pump, map sensor, IAC controller still doing same thing.
Chevy Code P1635 – 5 Volt Reference Circuit
Circuit Description
The PCM uses the 5 Volt Reference A circuit as a sensor feed to the following sensors:
  • TP sensor
  • MAP sensor
  • EGR Valve Pintle Position sensor
  • Fuel Tank Pressure Sensor
The PCM monitors the voltage on the 5 Volt Reference A circuit. If the voltage is out of tolerance, the PCM will set DTC P1635.
Conditions for Running the DTC
The ignition is ON.
Conditions for Setting the DTC
  • The PCM detects a voltage out of tolerance condition on the 5 Volt Reference A circuit.
  • Above condition for longer than 10 seconds.
Action Taken When the DTC Sets
  • The PCM will illuminate the malfunction indicator lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed.
  • The PCM will store conditions which were present when the DTC set as Freeze Frame/Failure Records data.
Conditions for Clearing the MIL/DTC
  • The PCM will turn OFF the malfunction indicator lamp (MIL) during the third consecutive trip in which the diagnostic has run and passed.
  • The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
  • The DTC can be cleared by using a scan tool.
Diagnostic Aids
Inspect for the following conditions:
Many situations may lead to an intermittent condition. Perform each inspection or test as directed.
NOTE
Important:
Remove any debris from the connector surfaces before servicing a component. Inspect the connector gaskets when diagnosing or replacing a component. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion.
  • Loose terminal connection
  • Use a corresponding mating terminal to test for proper tension. Refer to Testing for Intermittent Conditions and Poor Connections , and to Connector Repairs in Wiring Systems for diagnosis and repair.
  • Inspect the harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and faulty terminal to wire connection. Refer to Testing for Intermittent Conditions and Poor Connections , and to Connector Repairs in Wiring Systems for diagnosis and repair.
  • Damaged harness—Inspect the wiring harness for damage. If the harness inspection does not reveal a problem, observe the display on the scan tool while moving connectors and wiring harnesses related to the sensor. A change in the scan tool display may indicate the location of the fault. Refer to Wiring Repairs in Wiring Systems for diagnosis and repair.
  • Inspect the powertrain control module (PCM) and the engine grounds for clean and secure connections. Refer to Wiring Repairs in Wiring Systems for diagnosis and repair.
If the condition is determined to be intermittent, reviewing the Snapshot or Freeze Frame/Failure Records may be useful in determining when the DTC or condition was identified.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2. NOTE
Important:
DTC must have failed this ignition to be properly diagnosed.
The 5 Volt Reference circuits have multiple PCM pins, be sure to test all components on the 5 Volt Reference A circuits only.
3. The 5 Volt Reference circuits have multiple PCM pins, be sure to test all components on the 5 Volt Reference A circuits only.
9. This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.
DTC P1635 5 Volt Reference Circuit
Step Action Value(s) Yes No
1
Did you perform the Powertrain On–Board Diagnostic (OBD) System Check ?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
  • Turn ON the ignition , Engine OFF.
  • With a DMM, Measure the voltage from the 5 Volt Reference circuit to a good ground.
Does the voltage measure near the specified value?
5.0 V
Go to Step 5
Go to Step 3
3
With a DMM observe the voltage while disconnecting all components connected to the 5 Volt Reference circuit one at a time.
Does voltage change when one of the components is disconnected?
Go to Step 8
Go to Step 4
4
Does the voltage measure less than the specified value?
4.9 V
Go to Step 6
Go to Step 7
5
  1. Reconnect the component tested earlier.
  2. Test another 5 Volt Reference circuit to a good ground.
5.0 V
Go to Step 9
Go to step 8
6
Test all 5 Volt Reference A circuits for a short to ground. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 10
Go to Step 9
7
Test all 5 Volt reference A circuit for a short to voltage. Refer Wiring Repairs in Wiring Systems,
Go to Step 10
Go to Step 9
8
Replace the affected component. Refer to appropriate component replacement.
Did you complete the replacement?
Go to Step 10
9
Replace PCM. Refer to Powertrain Control Module Replacement/Programming.
Go to Step 10
10
Use the scan tool in order to clear the DTCs
Operate the Vehicle within the conditions for running the DTC as specified in the supporting text .
Does the DTC reset ?
Go to Step 2
System OK
deb57
Recent My Questions
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
2 months ago
Jeep Wrangler TJ 97-2006 Clutch Replacement
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
2 months ago
Fuel Pump Driver Module (FPDM) 2014 Ford Explorer 3.5L
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
3 months ago
Just put these sick headlights on my Jeep Wrangler
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
4 months ago
Hole in valve cover 2017 Hyundai Santa Fe
Intake CVVT came apart and blew a hole in the valve cover. How much would something like that cause to…
6 months ago
BMW F30 Steering Wheel
12 months ago
