I have a problem with my Chrysler Grand Voyager 1997 2.4 SE manual.
10 years ago the shifter nob (transmission shifter) got loose so i can’t get it into any gear.
It happen again now and the mechanic i used back then is no more so i can’t ask him sadly.
Any one who can link me to some information about this problem ?
Repair guide or more information about this problem.
I need to get the car transported to my new mechanic but he never tried this repair before.
So to understand what the problem is.
The manual gear shifter stick inside the car got loose or broke it’s connection to the gear box.
I hope that make sense what i mean.
Thanks a lot.
BR
Lui Petersen
Denmark
Only thing that can be done would be to take it apart and look to see what has happened. Sometimes there is a bushing at the bottom of the shifter handle that it sets in that goes bad. This would be the first thing I would look for. Remove the shifter boot and access plate along with the shifter handle and look to see if there is any damage to the bushing.
Hi there
Thanks a lot for your replay. Much appreciated.
But when you say “take it apart” what do you mean, the gear box, the shifter or what.
Thanks again.
BR
Lui
The Shifter Assembly. Remove the shifter boot and access plate along with the shifter handle and look to see if there is any damage to the bushing.
