Home » Car Questions » How to scan SRS Codes without a Scan Tool
2012 Toyota Camry
I bought a 2012 Toyota Camry ELE repaired after a collision. The SRS light stays on. I have safely unplugged and checked the SRS connection under the passenger seat. I sent the SRS ECU to be reset and then re-installed it. The SRS light is still on. There are no OBD2 codes. What to do next?
If you have a scan tool you may connect it and pull the codes or do it without a scan tool. I have provided the procedures below for both scanning and clearing the present codes. I have also provided a list of corresponding diagnostic trouble codes.  Then check wiring and sensors that correspond to the present code or fault. These codes would begin with a B.
Scan Codes without a Scan Tool
  1. Turn ignition switch to Acc or On position.
  2. Wait approximately 20 seconds.
  3. Connect DLC terminal Tc and E1 or Tc and CG with special diagnosis check wire tool No. 09843-18020 or equivalent jumper wire.
  4. Read two-digit DTC from SRS warning lamp as blinks as follows:
    a. If lamp flashes two times per second, there are no DTCs stored.
    b. If a fault code is indicated, first digit will flash, then after 1.5 seconds elapse, second digit will flash.
    c. If more than one code is stored, 2.5 seconds will elapse, then second code will appear.
    d. DTC flashes will be displayed from smallest numerically to largest.
    e. After all stored DTCs have been read, 4.0 seconds will elapse and DTCs will be repeated.
Clearing Diagnostic Trouble Codes without a Scan Tool
  1. Connect two special diagnosis check wire tools No. 09843-18020 or equivalent jumper wires, to DLC terminals Tc and AB or Tc and CG.
  2. Turn ignition switch to Acc or On position and wait approximately six seconds.
  3. Alternately ground each jumper wire twice in one second cycles as follows:
    a. Ground Tc jumper for .5-1.5 second.
    b. Release Tc ground and immediately ground AB jumper within .2 second.
    c. Ground AB jumper for .5-1.5 second.
    d. Release AB ground and immediately ground Tc jumper within .2 second.
    e. Ground Tc jumper for .5-1.5 second.
    f. Release Tc ground and immediately ground AB jumper within .2 second.
    g. Ground AB jumper for .5-1.5 second.
    h. Release AB ground and immediately ground Tc jumper within .2 second.
  4.  Ground Tc jumper.
  5. SRS warning lamp will blink in a 50 milli-second cycle several seconds after clearing procedure is completed to indicate DTCs have been cleared.
Toyota Diagnostic Trouble Codes Interpretation
CodeDescription
Scan ToolSRS Lamp
B010013Short In D Squib Circuit
B010114Open In D Squib Circuit
B010211Short To Ground In D Squib Circuit
B010312Short To B+ In D Squib Circuit
B010553Short In P Squib Circuit
B010654Open In P Squib Circuit
B010751Short To Ground In P Squib Circuit
B010852Short To B+ In P Squib Circuit
B011043Short In Side Squib Righthand Circuit
B011144Open In Side Squib Righthand Circuit
B011241Short To Ground In Side Squib Righthand Circuit
B011342Short To B+ In Side Squib Righthand Circuit
B011547Short In Side Squib Lefthand Circuit
B011648Open In Side Squib Lefthand Circuit
B011745Short To Ground In Side Squib Lefthand Circuit
B011846Short To B+ In Side Squib Lefthand Circuit
B012627Lefthand Seat Belt Buckle Switch Fault
B012727Lefthand Seat Belt Buckle Switch Fault
B013063Short In P/T Squib Righthand Circuit
B013164Open P/T Squib Righthand Circuit
B013261Short To Ground In P/T Squib Righthand Circuit
B013362Short To B+ In P/T Squib Righthand Circuit
B013573Short In P/T Squib Lefthand Circuit
B013674Open P/T Squib Lefthand Circuit
B013771Short To Ground In P/T Squib Lefthand Circuit
B013872Short To B+ In P/T Squib Lefthand Circuit
B100031Air Bag Sensor Assembly Fault
B110031Air Bag Sensor Assembly Fault
B113524Half Connection Detection Fault
B114032Righthand Side Impact Air Bag Sensor Assembly Fault
B114133Lefthand Side Impact Air Bag Assembly Fault
B114234Door Side Impact Air Bag Sensor Righthand Fault
B114334Door Side Impact Air Bag Sensor Righthand Fault
B114435Door Side Impact Air Bag Sensor Lefthand Fault
B114535Door Side Impact Air Bag Sensor Lefthand Fault
B114836Front Air Bag Sensor Righthand Fault
B114937Front Air Bag Sensor Lefthand Fault
B115023Occupant Classification System Fault
B115228Passenger Air Bag ON/OFF Indicator Circuit Fault
B115325Seat Position Sensor Assemble Fault
B115438Air Bag Sensor Rear Righthand Fault
B115539Air Bag Sensor Rear Lefthand Fault
B115615Front Righthand Air Bag Sensor Fault
B115715Front Righthand Air Bag Sensor Fault
B115816Front Lefthand Air Bag Sensor Fault
B115916Front Lefthand Air Bag Sensor Fault
B116083Short In Roof Panel Air Bag Righthand Squib Circuit
B116184Open In Roof Panel Air Bag Righthand Squib Circuit
B116281Short In Roof Panel Air Bag Righthand Circuit To Ground
B116382Short In Roof Panel Air Bag Righthand Circuit To B+
B116587Short In Roof Panel Air Bag Lefthand Squib Circuit
B116688Open In Roof Panel Air Bag Lefthand Squib Circuit
B116785Short In Roof Panel Air Bag Lefthand Circuit To Ground
B116886Short In Roof Panel Air Bag Lefthand Circuit To B+
B118017Short In D Squib 2nd Step Circuit
B118118Open In D Squib 2nd Step Circuit
B118219Short In D Squib 2nd Step Circuit To Ground
B118322Short In D Squib 2nd Step Circuit To B+
B118557Short In P Squib 2nd Step Circuit
B118658Open In P Squib 2nd Step Circuit
B118755Short In P Squib 2nd Step Circuit To Ground
B118856Short In P Squib 2nd Step Circuit To B+
B160283Lost Communication With Front Satellite Sensor Bus Righthand
B160383Righthand Front Satellite Sensor Bus Initialization Incomplete
B160784Lost Communication With Front Satellite Sensor Bus Lefthand
B160884Lefthand Front Satellite Sensor Bus Initialization Incomplete
B161013Righthand Front Air Bag Sensor Circuit Fault
B161283Lost Communication With Righthand Front Air Bag
B161383Righthand Front Air Bag Initialization Incomplete
B161514Lefthand Front Air Bag Sensor Circuit Fault
B161784Lefthand Front Air Bag Sensor Circuit Fault
B161884Lefthand Front Air Bag Initialization Incomplete
B162021Lefthand Side Air Bag Sensor Circuit Fault
B162281Lost Communication With Lefthand Side Air Bag Sensor Assembly
B162381Lefthand Side Air Bag Sensor Assembly Initialization Incomplete
B162522Righthand Side Air Bag Sensor Circuit Fault
B162782Lost Communication With Righthand Side Air Bag Sensor Assembly
B162882Righthand Side Air Bag Sensor Assembly Initialization Incomplete
B163023Lefthand Rear Air Bag Sensor Circuit Fault
B163281Lost Communication With Lefthand Rear Air Bag Sensor
B163381Lefthand Rear Air Bag Sensor Initialization Incomplete
B163524Righthand Rear Air Bag Sensor Circuit Fault
B163782Lost Communication With Righthand Rear Air Bag Sensor
B163882Righthand Rear Air Bag Sensor Initialization Incomplete
B164281Lost Communication With Lefthand Satellite Sensor Bus
B164381Lefthand Satellite Sensor Bus Initialization Incomplete
B164782Lost Communication With Righthand Satellite Sensor Bus
B164882Righthand Satellite Sensor Bus Initialization Incomplete
B165032Occupant Classification System Fault
B165335Seat Position Sensor Assembly Circuit Fault
B165537Lefthand Seat Belt Buckle Switch Assembly Fault
B166043Passenger Air Bag ON/OFF Indicator Light Circuit Fault
B166245Indicator Light Circuit Fault
B1771Passenger Side Buckle Switch Circuit Fault
B1780Lefthand Front Occupant Classification Sensor Circuit Fault
B1781Righthand Front Occupant Classification Sensor Circuit Fault
B1782Lefthand Rear Occupant Classification Sensor Circuit Fault
B1783Righthand Rear Occupant Classification Sensor Circuit Fault
B1785Lefthand Front Occupant Classification Sensor Collision Detection
B1786Righthand Front Occupant Classification Sensor Collision Detection
B1787Lefthand Rear Occupant Classification Sensor Collision Detection
B1788Righthand Rear Occupant Classification Sensor Collision Detection
B1790Air Bag Assembly Center Communication Sensor Circuit Fault
B1793Occupant Classification Sensor Power Supply Circuit Fault
B1794Open In Occupant Classification ECU Battery Positive Live
B1795Occupant Classification ECU Circuit Fault
B1796Sleep Operation Failure Of Occupant Classification ECU
B180051Short In D Squib Circuit
B180151Open In D Squib Circuit
B180251Short In D Squib Circuit To Ground
B180351Short In D Squib Circuit To B+
B180552Short In P Squib Circuit
B180652Open In P Squib Circuit
B180752Short In P Squib Circuit To Ground
B180852Short In P Squib Circuit To B+
B181053Short In D Squib Dual Stage – 2nd Step Circuit
B181153Open In D Squib Dual Stage – 2nd Step Circuit
B181253Short In D Squib Dual Stage – 2nd Step Circuit To Ground
B181353Short In D Squib Dual Stage – 2nd Step Circuit To B+
B181554Short In P Squib Dual Stage – 2nd Step Circuit
B181654Open In P Squib Dual Stage – 2nd Step Circuit
B181754Short In P Squib Dual Stage – 2nd Step Circuit To Ground
B181854Short In P Squib Dual Stage – 2nd Step Circuit To B+
B182055Short In Lefthand Side Squib Circuit
B182155Open In Lefthand Side Squib Circuit
B182255Short In Lefthand Side Squib Circuit To Ground
B182355Short In Lefthand Side Squib Circuit To B+
B182556Short In Righthand Side Squib Circuit
B182656Open In Righthand Side Squib Circuit
B182756Short In Righthand Side Squib Circuit To Ground
B182856Short In Righthand Side Squib Circuit To B+
B183057Short In Lefthand Roof Panel Squib Circuit
B183157Open In Lefthand Roof Panel Squib Circuit
B183257Short In Lefthand Roof Panel Squib Circuit To Ground
B183357Short In Lefthand Roof Panel Squib Circuit To B+
B183558Short In Righthand Roof Panel Squib Circuit
B183658Open In Righthand Roof Panel Squib Circuit
B183758Short In Righthand Roof Panel Squib Circuit To Ground
B183858Short In Righthand Roof Panel Squib Circuit To B+
B186064Short In Driver Side Knee Air Bag Squib Circuit
B186164Open In Driver Side Knee Air Bag Squib Circuit
B186264Short To GND In Driver Side Knee Air Bag Squib Circuit
B186364Short To B+ In Driver Side Knee Air Bag Squib Circuit
B190073Short In Lefthand P/T Squib Circuit
B190173Open In Lefthand P/T Squib Circuit
B190273Short In Lefthand P/T Squib Circuit To Ground
B190373Short In Lefthand P/T Squib Circuit To B+
B190574Short In Righthand P/T Squib Circuit
B190674Open In Righthand P/T Squib Circuit
B190774Short In Righthand P/T Squib Circuit To Ground
B190874Short In Righthand P/T Squib Circuit To B+
