Was wondering if you have any information regarding the wiring harness as shown below. Was looking for any PDF documents referring to the electrical diagrams. Also as where I can purchase the connector / cable shown below. Keep in mind, the connector / harness I am referring too plugs into the 645-205 black female connector shown in the amazon link. The connector I am trying to purchase with harness is what is shown in the first picture and on the right in the second picture.
Dorman 645-205 Pigtail Connector-Headlight
Not sure of any documentation on this. However I think i can help with this. The wiring harness would be referred to as the head light/lamp wiring harness.
Part No. For 2008 – 2010 Cobalt OEM GM Head Light Wiring Harness is 20760562 on eBay is only a small socket, do not purchase this thinking you will get the entire wiring harness.
![](https://www.freeautomechanic.com/mechanic/forum/wp-content/uploads/2020/02/2008-chevy-cobalt-headlight-wiring-harness-.jpg)
Therefore, in order to get the correct wiring harness you may need to contact your local dealership. There is of course the option of going used at a junkyard.
The following is the correct entire vehicle harness for headlight / foglights.
GM Part Number 20760566
![GM-Part-Number-20760566](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIxMTk2IiBoZWlnaHQ9IjgwMCIgdmlld0JveD0iMCAwIDExOTYgODAwIj48cmVjdCB3aWR0aD0iMTAwJSIgaGVpZ2h0PSIxMDAlIiBmaWxsPSIjZmZmZmZmIi8+PC9zdmc+)
Thanks “ThePie” for the inspiration to look at the ACDelco online parts catalog. Found just the connector available in case that is all you need. . Part Number: PT246
![Headlight Connector - 2008 Chevy Cobalt](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIzNjEiIGhlaWdodD0iMTIzIiB2aWV3Qm94PSIwIDAgMzYxIDEyMyI+PHJlY3Qgd2lkdGg9IjEwMCUiIGhlaWdodD0iMTAwJSIgZmlsbD0iI2ZmZmZmZiIvPjwvc3ZnPg==)
