Starter Replacement
NOTE
Applicable vehicles:
G 2.4 DOHC
Removal
- Disconnect the battery negative cable.
- Disconnect the starter cable (A) from the B terminal (B) on the solenoid (C), then disconnect the connector (D) from the S terminal (E).
- Remove the 2 bolts holding the starter, then remove the starter.
- Installation is the reverse of removal.
- Connect the battery negative cable to the battery.
NOTE
G 2.7 DOHC
Removal
Installation
- Reverse procedure to install and torque starter mounting bolts to 41 ft. lbs.
