Home » Car Questions » Low Battery Light stays 2012 Ford Fiesta
ford-fiesta
Low Battery Light stays on even with new battery and good charging voltage from alternator. Any suggestions? I believe this has been discussed in the past.
You are right. A quick search for “fiesta battery light” from our website search bar returned: FORD FIESTA BATTERY LIGHT ON SOLVED
From the Manual:
When battery (or PCM) is disconnected and connected, some abnormal drive symptoms may occur while vehicle relearns its adaptive strategy. Charging system set point may also vary. Vehicle may need to be driven to relearn its strategy.
How to reset Battery Monitor Sensor
Avoid Expensive Garage Repairs: Re-setting a Ford Battery Monitor Sensor Yourself
