LOST KEY FOB . CALLED LOCKSMITH ,HE CUT A KEY . IT TURNED THE ENGINE ON. THEN HE WENT TO START IT AGAIN AND NO START.,. HE WORKED ON FOR 24 HOURS. NEXT DAY IT STARTED BUT YOU CANT OPEN WINDOWS UNLOCK DOORS ETC. I DROVE TO THE STORE AND AGAIN IT WONT START.,. HELP
Seek your local dealership for MINI Cooper keys and or replacement fobs. There may be an issue with the immobilizer. Not much information on this in the resources I have.
On vehicles with electronic vehicle immobilization, comply with the instructions of the BMW diagnosis system. Each control unit is programmed with certain basic values, which serve as mean values. The control unit receives different input values, depending on engine condition, which are compared with the stored values. The adaptive system compares the input values with the stored map values. The control commands are routed to the relevant actuators.
