Home » Car Questions » 1989 s10 4×4 2.8 liter wiring diagrams
1989-cehvy-s10-4x4
put gas in throttle body will run, suddenly no headlights,no power to switch,all fuses is good,no power fuel pump relay, measure voltage fuel pump wires,5 volts, radio doesn’t illuminate just static,sure don’t have idea what it’s , everything worked,till I put transmission and transfer case back in the truck
replaced transmission,transfer case,charged battery, then suddenly no headlights,radio static doesn’t illuminate,no power to fuel pump or relay,
I would think the first place to look would be the battery connections. Make sure they are clean and secure. Then fully charge the battery before testing again. I have added a wiring diagrams below for reference. Check your Ground connections at both ends. This is an old vehicle so rust is your electrical systems worst enemy. As for the Fuel pump. It uses the ECM B fuse which is separate from the headlight fuse. So for both to have an issue at the same time I would look at the bigger connections such as the battery connections or cables.
1989 Chevy S10 Headlight Wiring Diagram
1989-chevy-s10-headlights-wiring-diagram
1989 Chevy S10 2.8L Engine Wiring Diagram
1989-chevy-s10-fuel-pump-wiring-diagram
6 thoughts on “1989 s10 4×4 2.8 liter wiring diagrams”
  1. okay,I did more research went bought electrical ignition switch, bottom steering column, I’ll put it on try it ,things getting no power other accessories some, researching said be likely ignition switch,but thanks for help
  2. thanks,did more research things not getting power,other accessories some power went bought electrical ignition switch, bottom steering column,try ,just 20 dollars, autozone,put it on see things back normal
  3. strange,found no problems wiring,3 fuses not getting power, decided jump power from one fuse to other ,fuel pump run,started truck,those fuses with no power suddenly had power truck running, strange
