Home » Car Questions » Honda engine burned 2 quartz of oil in 5 days
2003 Honda Accord
hello,
last week i have installed a new ( used ) engine for my honda accord 2003 2.4L .
after driving for 10 minutes, I had a problem, it cuts off and in scanner i read this :
and the engine burned 2 quartz of oil in 5 days !!! i replaced the VTEC Oil Pressure Switch, but i had not  a good result.
so I replaced again the engine. and I had the same problem, and i replaced the VTEC Oil Pressure Switch, but i had not  a good result, in addition I have now two new codes :
so do you think that the mechanics made something wrong in wires ? or what could it be ?
thank you
Could you let me in on the exact codes? burning 2 quarts of oil in 5 days. Would suggest a compression test on each cylinder.
SOLD 2003 Honda Accord EX I-VTEC 99K Miles Meticulous Motors Inc Florida
